Страница 5 из 9 ПерваяПервая ... 34567 ... ПоследняяПоследняя
Показано с 41 по 50 из 87
Тема: JTDX
    UT2GA
    KN66hp
    JTDX
    Ссылки jtdx_2.2.159:
    13th March 2022
  2. #41
    JTDX 2.2.160-rc9
    ADD Дополнительная информация. Additional info.
    There is JTDX 160rc9, changelog:
    - TCI: fix big frequency split cases
    - TCI: use IF limits from EESDR
    - TCI: attempt to fix band change from EESDR
    - TCI: fix band change for other modes than FT8
    - TCI: band tci command changed from VFO+IF to DDS+IF
    - FT8 decoder: improved decoding of signals
    - FT8 decoder: support up to 180 decoded messages per interval, prevent decoder crash if this number exceeded
    - FT4 decoder: RR73 message hash problem
    - SuperFox decoder: search for SuperFox signal in various frequency spans, set initial RX frequency to 750 Hz
    - prevent rare wrong unpacking of the special DXpedition message
    - updated unpacking of type 3 messages (PACCdigi contest etc)
    - right mouse button click on 'Halt Tx' enables Waiting mode
    - do not consider RRR message for enabling tx when halt/resume tx is active
    - show correct statistics after change logbook filtering
    - added more hints in showqsos window
    - display Hound frequency control status on button
    - added WindowStaysOnTopHint flag for logqso window
    - support logging satellite QSO with no CAT
    - support suffix search in compound callsign, for example setting 'wanted pfx/sfx' to VP9 will search for VP9/AA1AAA and AA1AAA/VP9 callsigns
    - switch off Enable Tx button if band is changed from rig
    - fix beep sound notification for wanted stuff
    - pskreporter 10GHz fix
    - change program name from esdr to ExpertSDR2 at sending to pskreporter
    - databases & ALLCALL7 updated
    - translation updates
    - JTDX 2.2.160-rc9 Windows/Mac builds made with modified Hamlib, based on Hamlib commit https://github.com/Hamlib/Hamlib/com...bcf8ca03bebf1f
    Builds of JTDX 2.2.160-rc9 are made with shared Hamlib libraries,
    such approach shall allow on Windows and Linux OS to apply recent Hamlib patches with no need to rebuild JTDX. On Windows OS users can replace libhamlib-4.dll file to apply Hamlib patch,
    Mac and Windows users can update Hamlib or revert update to previous version in JTDX configuration Radio tab.
    Linux OS: Hamlib build is supplied as standalone package and shall be installed first (prior to JTDX installation). Hamlib patches can be applied via Hamlib upgrade.
    Information on Hamlib changes is available via this link: https://github.com/Hamlib/Hamlib/commits/master
    Hamlib open/resolved issues: https://github.com/Hamlib/Hamlib/issues
    Скрытый контент: У вас недостаточно привилегий.
    F6CTT
    IN97HV
    Hello Vladimir and all
    this RC9 version runs perfectly in remote mode ExpertSdr3 1.0.12 Beta 27.05.2025 with a Sunsdr2 Pro
    i had some problems to switch band with split (mode TRX) and no problem now
    73 and thank you
    Joseph F6CTT
  4. #43
    RA9UEP
    NO35CI
    Владимир, а где сейчас можно скачать RC9 ? Если не секрет ?
  5. #44
    Если пользователи в этой теме не нашли ответ на поставленный вопрос, то можно спросить у "arvo.jarve" <arvo.jarve@hotmail.com>
    RA9UEP
    NO35CI
    Владимир спасибо за ответ Вас понял.
  7. #46
    SPOTTER
    YO2MAX
    KN15MR
    Hi Vladimir,
    Why don't we have rights to view the download links with the new RC9 version?
    Razvan
    - - - Добавлено - - -
    Yes, I have now seen the rules for viewing certain content.
  8. #47
    Цитата Сообщение от YO2MAX Посмотреть сообщение
    Razvan
    Simple. Set up sending spots to our server https://udp.rdrclub.ru/
    SPOTTER
    YO2MAX
    KN15MR
    Hi all,
    I would like to thank Arvo, ES1JA, for implementing some useful features in the RC9 version of JTDX for those working on satellites, namely the QO-100. Everything now works perfectly, including logging QSOs on the QO-100 and reporting correctly on pskreporter. Thanks, Arvo!
    YO2MAX, Razvan
  10. #49
    F6CTT
    IN97HV
    Hello all
    a part of my setup with eesdr
    i try to send this image
    Maybe it's OK
    73 Joseph
  11. #50
    SQ6VRS
    JO80PL
    Audio settings according to your device's sound card. These settings are based on the Icom 7300. I don't know if they will help.
    Привет, Владимир. Я просто не знаю, знает ли разработчик этого журнала, что файл программы не проходит проверку безопасности Windows 11 и удаляет установку файла как угрозу.
