День активности РЦРК
Страница 4 из 8 ПерваяПервая ... 23456 ... ПоследняяПоследняя
Показано с 31 по 40 из 76
Тема: JTDX
    UT2GA
    KN66hp
    JTDX
    Ссылки jtdx_2.2.159:
    13th March 2022
  2. #31
    jtdx-2.2.160-rc4
    There is 160-rc4, changelog:
    - reworked autoAGC math, push snr and noise values for every interval, getting autoAGC values prior start of decoding,
    changes in noise calculation math, use autoAGC at TCI start
    - support autoAGC through Hamlib, added 'Try Auto AGC' option control in settings of Radio tab: it is working
    with TCI and some radios via Hamlib
    - save/restore AGC value by band
    - restore ReplyTx state when QSO broken at ReplyTx state, do not change Rx when entering into ReplyTx
    - fixed bug for setting tx period from udp message, thanks to Andy ZL1VAH
    - spot CQ messages without grid for nonstandard callsigns
    - set TX frequency correctly when VFO changed from rig
    - fix band definition frequencies, thanks to Yukio JG1APX
    - attempt to fix unneeded ClearDx when 'reply to other' detected, thanks to Fred K1IO
    - do not change RX audio frequency when entering into ReplyTx
    - unified band detection, improve performance of Notification checks
    - added polling transceiver change from WSJT-X
    - QO-100 preliminary support
    - fix to exact frequencies for QSO loggig
    - increase shared memory size for Mac builds
    - display time offset on Sync button
    - filter out false AP mask decodes with wrong report
    - new tooltips to Enable Tx, Sync, AGCc UI buttons
    - added some 'prefix to grid' mapping patches
    - added debug extension to revision name
    - display logos into 'About' window
    - fixed TCI transmission for long intervals
    - attempt to handle band memory with TCI
    - added TCI audio buffering time control
    - attempt to reduce Configuration UI window size
    - implemented US State notification, add State to logbook at QSO logging
    - implemented GRID square and US State databases, compact databases
    - user can open pskreporter map from UI with users's callsign and current band/mode
    - disable TX when message from called station was not decoded at 4 consecutive RX intervals
    - changed functionality from 'Halt TX if operator I called answered to other operator' to
    'Halt/Resume TX if operator I called answered to other operator', calling will be resumed at end of QSO
    - patch to 4-char CQ direction
    - move CRC computation to Fortran code in FT8 decoders, use Fortan code for crc computation in TX message encoding
    - split TX/RX FT8 message and wave generations
    - fixed Autoselect for old JT modes
    - added distro name and version to package name for deb based distros
    - DXCC name changed from 'United States' to 'United States of America'
    - use common parameter to limit maximum number of decoded in an interval messages, set value to 160
    - added download database file updates from Internet, grid_data.bin state_data.bin changed to compressed format
    - ALLCALL7.TXT update as of 20230825
    - translation updates
    - JTDX 2.2.160-rc4 builds made with modified Hamlib, based on Hamlib commit https://github.com/Hamlib/Hamlib/com...ee2370a45959a0 as of August 29th, 2023
    Скрытый контент: У вас недостаточно прав для просмотра - требуется регистрация.
    ADD #919:
    Цитата Сообщение от ES1JA
    I intentionally removed enabling Tx from udp. Only way to prevent using JTDX as a slave for qso robots using udp. Sry.
    вышел тестовый релиз 160-rc7 c SUPERFOX....
    SPOTTER
    IK6QRE
    JN63rh
    Cool
    Hello.
    I need 32A-amd64 debian version (linux) of that release (160-rc7).
    Its filename is something like jtdx_2.2.###-32A_amd64_ub20.deb
    Can you help me?
    Thank you in advance.
    73
    Sergio
    Привет.
    Мне нужна версия Debian 32A-amd64 (linux) этого релиза (160-rc7).
    Его имя файла что-то вроде jtdx_2.2.###-32A_amd64_ub20.deb
    Вы можете мне помочь?
    Заранее спасибо.
    73
    Серхио
  5. #34
    Sorry Sergio...I have only windows version....
    Hello all,
    There is 160rc7, changelog:
    - added WSJT-X SuperFox mode decoder
    - added some changes to Hamlib Tranceiver from WSJT-X code
    - validate last grid from sources when size is the same
    - databases updated, ALLCALL7.TXT update as of 20240724
    - JTDX 2.2.160-rc7 builds made with modified Hamlib, based on Hamlib code with last commit https://github.com/Hamlib/Hamlib/com...e7aa783f519f91 as of August 3rd, 2024
    Builds of JTDX 2.2.160-rc7 are made with shared Hamlib libraries,
    such approach shall allow on Windows and Linux OS to apply recent Hamlib patches with no need to rebuild JTDX. On Windows OS users can replace libhamlib-4.dll file to apply Hamlib patch,
    Mac and Windows users can update Hamlib or revert update to previousversion in JTDX configuration Radio tab.
    Linux OS: Hamlib build is supplied as standalone package and shall be installed first (prior to JTDX installation). Hamlib patches can be applied via Hamlib upgrade.
    Information on Hamlib changes is available via this link: https://github.com/Hamlib/Hamlib/commits/master
    Hamlib open/resolved issues: https://github.com/Hamlib/Hamlib/issues
    MS Windows debug build is dedicated to trace down possible JTDX and TCI bugs, it also logging Hamlib errors, this build can be installed in case any related issue being observed.
    Debug log will be recorded in JTDX QSO log directory, file name is jtdx_debug.txt
    Also in JTDX log directory tx.wav file will be recorded with TX signal for transmission over TCI interface.
    WhatsApp Image 2024-08-12 at 10.52.18.jpeg WhatsApp Image 2024-08-12 at 10.52.26.jpeg
    из https://forum.qrz.ru/377-jt65-jt9-ws...ml#post2044465
    Должно в зелоёном поле быть "SHound"
    При каждом перезапуске программы JTDX, режим SHound нужно переподключать. По-умолчанию будет запускаться "обычный" FT8
    Проводил сегодня сравнение по приему FT8 ("обычного") между JTDX RC3 и RC7. Сразу оговорюсь - т.к. я использую SunSDR2, то звук был через TCI.
    Сравнение проводилось на диапазоне 24 Мгц, принимал слабый сигнал RI1ANE. Диапазон был достаточно сильно загружен.
    Итог сравнения - RC3 безоговорочно по чувствительности выигрывает у RC7. На RC7 RI1ANE практически не принимался, на RC3 спокойно принимался с уровнем -21.
    Хочу особо отметить, почему я решил провести это сравнение: у меня JTDX RC3 и RC7 на прием FT8 работают очень сильно "по разному" - в чем это заключается: в RC3 я ручку усиления ПЧ выкручиваю практически до максимума, в результате чего становится возможным прием слабых сигналов, в RC7 так сделать нельзя - если установить усиление ПЧ больше, чем на половину, прием сигналов вообще прекращается из-за перегрузки.
    Итог: я себе установил и JTDX RC3 и RC7 - в RC7 я работаю SF, а при работе в обычном FT8 переключаюсь на RC3.
    SPOTTER
    IK6QRE
    JN63rh
    Many many many thanks!!!
    Большое-большое спасибо!!!
    Sergio
  8. #37
    ik3sso
    jn65in
    16-bit audio builds:
    32-bit audio builds:
    Ciao! A piece of information, it is possible to make a change in the "wait Call" command after the 4 Tx ", that is Insert the call in the "Gen msg" and put the "wait call" command without sending in tx 4 times the call without answer. This is to facilitate the waiting for a cq call dx, and automatically the answer in tx starts. I hope you understood the question. Thanks Mauro ik3sso.
    Mauro
  9. #38
    JTDX 2.2.160-rc8
    There is 160rc8, changelog:
    - TCI: added possibility to select 12000 sampling rate and two byte integer in 16bit audio JTDX build or
    three byte integer in 32bit audio JTDX build instead of four byte float audio data format
    - TCI: set waterfall freq position in EESDR on band change
    - TCI: spot rig info for TCI devices to psk_reporter
    - TCI: reworked set VFO commands
    - TCI: fixed bug in initial report of AGC value set in EESDR
    - TCI: fix some WSPR issues
    - FT8 decoder: 3 decoding cycles, each had 3 decoding passes inside, now replaced with 9 decoding passes, better matching to user's CPU resources
    - improved decoding of FT8 signals
    - implemented message exchange system as per WSJT-X message exchange format, can be enabled via Misc tab -> Enable message system
    - integrated latest WSJT-X SuperFox mode decoder
    - added statistics for big grids
    - prevent selection of even TX interval if Hound mode is enabled
    - search for wanted prefix also at end of compound callsign
    - refuse setting RR73 as grid in tx1
    - restore long time broken setting grid for type 2 CQ messages, for example 4O/
    - multiple changes in prefix-to-grid mapping
    - log and configuration: apply more complex checking for callsign and grid entering
    - added SWL option in General tab of Configuration to support SWL callsigns
    - fix bug in unpacking type4 TX message introduced after 160rc4, make sure MYCALL is used at unpacking type5 TX message
    - prevent autoselect from wrong period in all modes
    - DX multislot operation: fix Halt Tx if 'reply to other' is set, proper determining DX Call frequencies
    - support type5 message unpacking for EU VHF contest
    - psk_reporter: reduce max payload from 1400 to 1200, credits to David KD0BTO
    - changes to hash12 handling, reduce chances of callsign collision
    - skip checking /QRPP callsigns in CQ messages
    - databases updated, ALLCALL7.TXT update as of 20250223
    - added translation to Latvian language
    - JTDX 2.2.160-rc8 builds made with modified Hamlib, based on Hamlib code with last commit https://github.com/Hamlib/Hamlib/com...bcf8ca03bebf1f
    as of February 18th, 2025
    Builds of JTDX 2.2.160-rc8 are made with shared Hamlib libraries,
    Mac and Windows users can update Hamlib or revert update to previous version in JTDX configuration Radio tab.
    Language translation: some new phrases added, need in translation, please.
    Templates and related source code 160-rc8 as of February 23rd, 2025 can be downloaded from https://drive.google.com/file/d/1ldf...ew?usp=sharing
    SPOTTER
    YO2MAX
    KN15MR
    Hello everyone,
    I also have a question, as a JTDX user, is it not possible to introduce in a later version of JTDX v160, in the QSO saving mode in ADIF format, the saving of the following optional parameters (see attached image): Reception Frequency, Prop Mode, Satellite Name, Sat Mode, useful data for those who want to use JTDX on satellites?
    Maybe even fullduplex mode?
    These can be found in the improved versions of DG2YCB's WSJT-X, but unfortunately, as many users have discovered, JTDX decodes many more stations in FT8/FT4 than any version of WSJT-X.
    Thanks in advance!
    YO2MAX, Razvan
    Цитата Сообщение от YO2MAX Посмотреть сообщение
    I also have a question, ... a later version of JTDX v160 ...
    Good day Razvan.
    There is no co-author of the project on our forum. I recommend contacting Arvo, ES1JA in the profile topic qrz.ru.
