Показано с 1 по 7 из 7
Тема: MultiPSK
    MultiPSK
    MultiPSK last version 4.51
    HELP Files
    Патч для версии 4.48.5 - отправка QSO на сервер RDRC:
    https://groups.io/g/multipsk/topic/m...sion/107669721
    This test version 7 proposes a possibility to export a QSO towards a WEB server via UDP: http://f6cte.free.fr/MULTIPSK_4_48_6_test_version_7.zip
    Paste this address in your Internet Explorer or equivalent. Download the file.
    Extract the ZIP file and replace the “official” Multipsk.exe. Before, make a copy of the “official” Multipsk.exe. It is also proposed new help manuals (chm files).
    Exporting a QSO via UDP to a WEB server
    It is given the possibility to export a QSO towards a WEB server via UDP, while recording a QSO (by pushing on the "QSO->Log" button or on the "DXKeeper" button). Afterwards, for example for the udp.rdrclub server, the activity (spots) can be seen here: https://udp.rdrclub.ru/
    To use this function, look at this document: в сообщении #3 этой темы.
    Modes supported by Multipsk::
    Phase Shift Keying modes:
    BPSK: BPSK31-63-125-250 / CHIP (64/128) / PSK10 / PSKFEC31 / PSKAM10-31-50 / PSK125R-250R-500R
    BPSK with SSTV: PSK63 F - PSK220F + DIGISSTV "Run"
    QPSK: QPSK31-63-125-250
    8PSK: VDL2
    MPSK: MT63
    PACKET BPSK1200-250-63-31 + APRS+ DIGISSTV "Run"
    MIL-STD-188-110A - 4285
    HFDL
    EPIRB-ELT-PLB beacons
    ARGOS (beacons/satellites)
    AUTEX
    ORBCOMM
    AERO
    EGC
    M10/M20
    LRPT
    On-Off Keying Modes: CW / NDB / CCW-OOK / CCW-FSK / QRSS
    Amplitude modulation mode: APT faxes (NOAA satellites)
    Frequency Shift Keying modes:
    PACKET: 110-300-1200 bauds + APRS+ DIGISSTV "Run"
    PACTOR 1 / AMTOR FEC-Navtex / AMTOR ARQ / SITOR A
    ASCII / RTTY 45-50-75-100-110-150-200 / SYNOP + SHIP / IEC 870-5
    1382 / BIIS / GMDSS DSC / ATIS / ACARS (VHF) / DGPS / NWR SAME / ARQ-E / ARQ-E3
    RS41(GFSK)
    DFM06-09
    LMS6
    Multi Frequency Shift Keying modes:
    MFSK8 / MFSK16/32/64 (+SSTV)
    OLIVIA / Contestia / RTTYM / VOICE
    THROB/THROBX
    DominoF / DominoEX / THOR
    PAX / PAX2
    Automatic Link Establishment (see http://www.hflink.com) MIL-STD-188-141A+
    ARQ FAE / ALE400 + ARQ FAE
    DTMF, SELCAL
    JT65 (A B and C)
    LENTUS
    COQUELET
    (RS ID / CALL ID)
    EM
    FT4, FT8, WSPR
    Base band modes: POCSAG, AIS, Packet 9600 bauds (G3RUH), DSTAR, C4FM, DMR, P25
    Hellschreiber modes: FELD HELL / FM HELL(105-245) / PSK HELL / HELL 80
    Graphic modes: HF FAX / SSTV (+QR Code) / PSK SSTV modes (mentioned above) / MFSK16 SSTV (mentioned above)
    PPM (by positioned pulses) modes: mode S (ADS-B included)
    DSP modes: Filters / Analysis / Binaural CW reception
    RTTY, CW, BPSK31, BPSK63 and PSKFEC31 Panoramics
    Identifiers: Video ID / RS ID / Call ID
    TCP/IP digital modem
    Integered SdR demodulator/modulator
    Последний раз редактировалось RW6AVK; 04.02.2026 в 12:55. Причина: 4.51
    Вопрос к пользователям этого софта - есть ли какой-либо "механизм" отправки (трансляции) занесенного в лог QSO посредством UDP/TCP?
    В мануале есть только краткая глава "Use of the Multipsk logbook and logging of an external logbook (DXKeeper...)" [стр. 993]
    Patrick, F6CTE реализовал в Multipsk отправку QSO на внешние сервера. По ссылке есть pdf (англ) файл с описанием как это сделать. В очередном релизе этот хелп сильно не изменится.
    Вложения Вложения
    New release of MULTIPSK 4.48.6
    Multipsk 4.48.7 Тестовая версия 1 — Кластер для пользователей Multipsk (SWL и радиолюбители)
    https://groups.io/g/multipsk/topic/m...sion/108652343
    Гугл-перевод:
    Кластер Multipsk для пользователей SWL и Ham Multipsk
    Этот кластер предназначен для радиолюбителей и SWL, использующих Multipsk. Нажав на пункт меню «Кластер», можно получить доступ к окну, которое позволяет обмениваться сообщениями между пользователями Multipsk. Сообщение состоит из следующих полей: дата-время UTC / позывной Ham или SWL / режим / частота XCVR / локатор / тема / возможное сообщение. У вас будет возможность увидеть положение пользователей на карте.
    MULTIPSK 4.49 New releases
    пришло письмо от коллеги, свой позывной он не указал:
    Здравствуйте!
    Сделал попытку перевести программу MultiPSK на русский язык.
    Может быть, кому-нибудь будет интересно и полезно.
    https://debend.website.yandexcloud.n...nslate-ru.html
    С уважением,
    Дмитрий
